1974 40 HP Question
Howza
I have a 40 hp Johnson Model# 40EL-74S, it runs great but will not charge back the battery. I looked to see if there was a stator but it is listed that it does not have one. Am I missing something simple?
kbait
Re: 1974 40 HP Question
Get your model number and go here: http://epc.brp.com/SiteMods/BRP_Public/BRP_Public_Login.aspx?ReturnUrl=/Index.aspx
Search for your exact model and look at the magneto section. If there's no charge coil under the flywheel, no charge for battery. I've heard folks using a small solar charge panel to maintain battery between uses. I have a '65 w/no generator (no charge coils back then), and my deep cycle seems to last forever, as it starts w/bump of the key, and I replaced running/interior lights w/LED..
F_R
Assuming it is electric start, it does have battery charging coils under the flywheel. It also has a 3 phase rectifier on the port side, attached to the bypass cover. Test the rectifier. It is way more likely to be the problem than the coils.
boobie
According to your model#, you should have a charging system on it.
Howza
That is a great website for schematics. Thank you.
