evilgenius877
- Joined
- Jun 4, 2008
- 27
my '74 50 hp is running a little rough. it idles real low and even stalls quite frequently. ai WOT it runs smooth but is not really at WOT i know it has more. and spits and sputters in mid range. i noticed that if i spray carb cleaner into the top carb it tries to die out naturally...but if i spray into the bottom the motor picks up power and speed. how do i adjust the carbs to where they should be ?
also.. i noticed the linkage between the two carbs were not right. the lock that holds the two metal shafts togheter was lose so that one of the carbs was not opening fully and it ran great like this. i tightened the screw and now it runs a little like crap as i mentioned above. how do i put these tow carbs in sync and how do i adjust the carbs so that it is running right and better ?
