scott_maier
Thread starter- Joined
- Mar 16, 2009
- 124
Motor won't start or fart. I've got 75psi on each cylinder, spark looks good but I did not use a spark tester- the coils look okay and points have been checked and re-gapped, i also "rebuilt" the carb with a new kit. Fuel is getting to carb and after a 5 or more pulls on the starter rope fuel will drip out the carb throat, but the plugs stay completely dry. Does this mean the leaf valves are stuck closed? I haven't tried spraying starter fluid or anything, because it should be sucking plenty of fuel in.
I don't know the history of the motor, but when I pulled the head off it was crudded up pretty good so I wouldn't be surprised if the leaf valves were dirty or stuck. I was just thinking for some reason that it is rare to have problems with the leaf valves...i must have heard or read that somewhere.
Anyway, any suggestions would be appreciated, I'm hoping I don't have to pull the powerhead again and check the leaf valves.
thanks in advance.
thanks in advance.
