1974 70 hp Evinrude impeller direction
strap_76
As I read thru my Solec I am not sure of the direction the impeller go in the water pump housing. When you remove impellor and housing and set it down with the impeller looking at you, facing up.....which way do the flanges point?
Joe Reeves
Re: 1974 70 hp Evinrude impeller direction
It doesn't matter. As soon as the engine turns over, the blades will flex in the proper direction.
However, the answer to your question..... the blades would point left due to the fact that the engine/driveshaft turns towards the right (clockwise).
strap_76
To be sure.....if the water pump is assembled and you are looking down at it in its operating position.....the flanges point left?
