1974 9.9
Starboardlean
Noticed my ol'reliable 9.9 was a little "off" today. Runs good and starts easy. Went to check points. Good. Sync is way off. Got all the adjustment out of ramp I can get. Roller is about 1 inch starboard of mark before throttle plate moves. Nothing looks overly worn. Something definitely needs renewing. Thoughts for fix?
Remove carburetor.------Look for missing screw for throttle plate.---Simple inspection and costs you nothing.
F_R
Old reliable 1974 9.9? Careful, you might make it "good as new", which was not good at all.
oldboat1
There should be a thick shoulder washer between the cam follower and the carb body. Is that in place?
Starboardlean
Yes the 9.9 is horrible.......
The throttle plate was secure, will check for washer in morning
