riley_2006
Thread starter- Joined
- Aug 2, 2010
- 4
FORGIVE MY HORRIBLE EXPLANATION OF THIS!!!
PROBLEM: the water isnt circulating correctly causing motor to overheat...the water pump appears to be ok and impeller looks fine, but the (seal i think) (rubber thing in the water pump).... is cracked.....Would that cause the water to not push up and flow out of the nostril...nose hole looking thing, and the water tube thing that comes out of the motor cover. and if that is the problem can i buy just that part, i found my impeller online if i needed to replace it, but cannot find the correct one to replace the whole water pump!!!!
1974 chrysler 120 HP model number 1207 HF
