1974 CV-18ss w/Ford 302 and VP280 I/O
Boatbuck
Can someone tell me, Is this boat considered an AQ200B on the Volvo Penta website? I have trouble figuring out which exhaust manifold will fit. Several people I have spoken to, ask which model of engine I have. As soon as I share that it has the 351 winsor heads, confusion ensues. Then they ask how many horse power, I answer 200hp, more confusion.
Grrrr. I have been on many other websites, seems like no one with this rare boat, has posted info on replacing these exhaust manifolds. I have no service manuals and presume that the 302 cu.in. Ford engine actually has the 351 W heads based on posts from other people.
QBhoy
I think for it to be an AQ anything…it would need to be driving an outdrive. I could be totally wrong here. But are CV18’s not usually jet drive ? With a Windsor driving a Hamilton jet or similar make of jet that I can’t quite think of now
QBhoy
I’m almost positive that’s not what you might be thinking it is at all. Or it’s not an aq200 anyway. I’m nearly sure the aq200 was a 5.0 GM engine. Usually mated to an old 270 or 280 outdrive.
Not an expert, but I’d say you’re right that it’s a ford Windsor engine. Most commonly found in things like mastercraft classic ski boats from the 70’s and early 80’s.
Boatbuck
It's not a jet boat, it has the VP280 outdrive. I think it was the CVX-18ss that had the jet drive. Mine is the CV-18ss, fitted with Volvo/Penta 280 outdrive.
Boatbuck
Here is a pic of the stock exhaust. I have an impeller on order and is why the pulley is disassembled.
QBhoy
Got you. Sounds a lovely boat. I’ve a cvx16.
Anyway. I think the VP with ford Windsor in the older days are a little confusing in their naming. I have a feeling that the older 351 vp Windsor might have been called the AQ240 or something similar. Hope that helps
