Redtruck12
Thread starter- Joined
- Jan 25, 2018
- 344
Update time again
i had been hesitant about poring the foam and concerned that my cavity temperature would be substantially lower that the surrounding temperature I can create with propane heaters in my tent.
i had completed the install of the additional bulkhead to enclose the centre channel at approx 3 feet from the stern and feel that limiting the opportunity for water to potentially get forward of my repair area is the wisest way to go.
the bulkhead was a bit of a pain to install as it is recessed under the already installed decking but went in well. I floated all the edges in P.B. And will reinforce with csm and or 1708 to be sure it is securely sealed.
as for the foam; I was pleasantly surprised at the expansion.
my temperature was 80-85f and I did my best to circulate air inside the cavity before poring the foam. My 2 side chambers required 2 one litre pores to completely fill with a good ooze from expansion holes which was much less than I figured.
Leaving me with what should be enough to completely fill the forward section of my centre channel running to the bow.
