Islandlaker
Thread starter- Joined
- Jul 4, 2016
- 23
My motor is not charging the battery. I have the manual in front of me and to check the rectifier was simple enough and mine tested good. I am confused though with checking the stator. The manual says the first step" disconnect the yellow lead (terminal 5) and yellow/gray(terminal 6) lead at the terminal block. connect the red meter lead to either yellow lead and meter black lead to ground to check for shorts. An infinite reading on HI ohms scale indicates the windings are good. Here is my first question, I can not find a ground wire, in this case are they referring too ground as any piece of metal in the motor? For this test I assumed ground meant a piece of metal in the engine (I touched the black lead to the piece of metal in the engine that was shown to be touching in one of the pictures). The meter remained unchanged at 1 when I did this test. Meaning when I set the meter to hi ohms the meter read 1 and when I did the test it stayed 1.
Test 2: Connect the ohmmeter (LO ohms) scale between the yellow and the yellow/gray leads. A reading of 1.0 ohms +/- .0 2ohms indicates the windings are good, and an infinite reading indicates the windings are open. During this test my reading is 1.5ohms.
So I probably sound like an idiot here but can someone help read my tests for me? To me I think I have a bad stator, but before I spend a couple hundred bucks to replace it I would like someone else's opinion. Also I did the obvious things like check wiring and leads. Everything looks good, looks like someone replaced the wiring in the motor recently as they are all in good shape. The only old looking wiring is the actual battery wires, they look original, but it seems to do the job starting wise at least. Thanks for all the help. I am slowly learning how to work on my motor with your guys help. I have already learned so much. Thanks again!
