I just recently purchased a 1974 Evinrude 25hp.It has had new points/condensor,plugs,fuel pump kit,a fresh rebuild on the carb.Sounds good right,Its not.It will only run on 1 cylinder.The upper cylinder is warm to the touch while running where as the bottom cylinder is hot.It has no power whatsoever.I replaced the coils on both cylinders,it did not help.Pulled the flywheel and double checked points,set at .020.I have a 10 hp merc that will run all over it.I'm waiting on a manual.I'm getting very aggravated at this dang thing.Any help would be greatly appreciated.Oh compression on both cylinders is 115# Thanks
