1974 Evinrude 25hp wont run.
tphoyt
The mixing instructions will be on your oil container.
Quicksilver products are for Mercury as stated on the label. Use a Johnson/ Evinrude product like HPF Pro.
I’m jumping off this train.
Best
I am going to be blunt once again.----It is 50 parts gasoline and 1 part oil.-----Or 2% ratio.-----Or 50 ounces of gasoline and 1 ounce of oil.-----Or 150 ounces of gasoline and 3 ounces of oil.-----If you are totally unsure of this 2 stroke mixing concept and unsure of how lubrication works.-----Then read some manuals or shop for a new 4 stroke motor.in a 2 stroke.------Failure to mix properly can lead to expensive mistakes / repairs.----Sorry.
j cat
Ok so I will be going to the stores to pick up some Penzoil today. What is the prefers mix ratio 5 gallons of regular or high test , to how much oil please.
Next is gear oil I am changing it in all 3 of my motors what is better I don’t see it but this is what my Walmart sells
Thanks as always
Dale
one gallon of gasoline 2.6 OZ of the 50-1 ratio ..
I did the gear oil change 24hrs to drain it out .. then if the gear oil is dirty , use engine oil 5-20wt on the top plug and drain out the bottom plug then the oil is clean ....then pump in the gear oil , bottom gear oil port ....
Dalejam
Wow, I only asked again for everyone seems to have a diffrent value. I am sorry if you are tired of my trivial questions, but I have come a long way by asking instead of assuming.
This was a place to get help correct.
Sorry you feel aggravated with my questions.
But I think I can fix my issues properly , by being informed , not guessing
Dalejam
Thank you for the help and information. Appreciate all the HELP….
Thanks
Dale
davidmbv
They sell a outboard 2stroke oil measure containers at Walmart or online for less 10$. You add the required amount of oil up to the line on the container for the amount of gas you are adding to your tank. It has different oil level lines on the clear container for what oil to gas ratio your outboard calls for. I have a 70 and 71 Johnson (OMC-Evinrude /Johnson) and the service manual calls for 50:1 oil to gas. The container also specifies oil to gas ratio for each brand of outboard etc. The mix container makes life easier, especially if your adding let’s say 3.5 gal of gas to top off your tank before fishing at 5am and don’t want to do math.
I add a gallon of gas to my separate/spare gas can, then add the oil, mix/shake gas can around, then add the rest of the gas I’m adding. Then Shake can around for few , then add the gas/oil mix to my boat’s gas tank. My boat’s gas tank is located under the middle bench seat and is a pain to take out and put back in. That’s why I have a separate gas can. Also nice to have few extra gallons laying around. I also add fuel stabilizer to the can at the time I add the oil. This is the way I do it. Many other ways. Like others said, 50:1 for your outboard.
I use regular gas not premium etc. The original Johnson 1971 service manual I got on eBay for 15$ was well worth the money, and it’s cool you can still find them for sale.
davidmbv
Also, I use Johnson/Evinrude 2stroke oil . Also available at Walmart, and at the hardware store near my place . I’m sure it’s no better than other brands but it said Johnson and I’m a fan. Think it’s 15-20$. Gallon lasts me awhile
Dalejam
That is awesome, thank you for all the great info and explaining it. I will work on it tomorrow . Today I was working on the 9,9 but I need a carb kit so it’s on hold . Back to my Johnson & Evinrude 1974 25 hp motors.
Thank you very much
As always appreciate the help
Dale
Dalejam
Picked up gear oil for the 3 drives. So I did the maintenance in the lower end. I am having issues keeping the motor running again. So as some one said to me troubleshoot don’t guess. The gas bulb had a leak on the output side. The carb would fill up with gas then run what was in the bowl, then stall. Grab the gas bulb it was soft. So found the bad connection fixed it but I also have a so so connection at the motor connection.
Do I have to keep the own connections can I change them out . If keeping them OEM how do you not get the to leak and Let air in .
Also have the grey line as the hose connections I read that is horrible line.
Last question about gas for today I am looking for instructions on how to rebuild the pumps I have. I am sure that is part of my issue too. I watched a YouTube video . Followed that but I still have a fuel delivery issue .
Dalejam
see info ...
read 3 times...then proceed to rebuilding :)
why not just disconnect at the carb...spin the engine to see if pump is or is not pumping out fuel
i did, it does spit fuel in a good flow. i even took it off and ran it with out fuel pump, but it runs and then dies. so i have to start over and double check. i did something wrong, just have to look at it again with fresh eyes.
thank you
Dale
Crosbyman
i did, it does spit fuel in a good flow. looks like it is working OK
better to look for another cause.
hook up a small fuel supply directly above & into the carb inlet nipple and see if the engine runs with the new source of fuel.
if it does not then the problem is between the carb inlet and the spark plugs :)
if it runs ok... then the problem is between the pump outlet hose and the "vented" fuel tank
Dalejam
thank you
Dale
funny youmention that. the tank i had was not venting. it was building up with pressure could see the tank bulging (plastic) so i ripped the little device out and fixed the issue so it will vent on its own now. the other thing is, since i did that the issues started to show up more. so i think the tank being under pressure, was forcing fuel to the motors, after the tank fix another issue came up. no fuel going to the carb bulbs or atleast replenishing it. so i did some reserach as i was told in the past from this board . i found out the fuel system is a closed system so if i end up with the primer bulb being soft and the carb has no gas init, i open the nut on the bottom of carb no gas. i can squeeze the primer bulb and gas will go to the carb no issues. so time to do more testing. the one way valve on primer bulb is not seeting properly, allowing gas to leave. fuel line at connections is leaking allowing air to get sucked into the system. hence causing the issue at hand no fuel. air is the problem getting into the fuel line system. so i orderd new connectors for the tank and motor, primer bulb. also will pick up 5/16 ID fuel line from Advanced auto. after that is replaced i will write how it worked out for me.
thank you all for the help
Dale
clemsonfor
Thanks as always
Dale
Walmart also has their own brand of lower unit oil which is what I use often. I think 50-1 is like 2.6? Ounce per gallon. Do yourself a favor and get a mix ratio bottle or cup. No guessing of bottle measure lines that are not that accurate. If your eyeballing use 3 oz per gallon to get close to 50-1. It's like a pint for 6 gallons I believe. Most bottles will tell you on them for like 3, 6,9, 12 gallons
clemsonfor
Dale
You can have a bad primer ball and it causes all kinds of weird issues.
Dalejam
I should correct my self. So from what I have read and looked up the fuel pumps that are on theses types of motors only use the pulse from
The crank case that makes the diafram pulse. I see it does
Not do to much more then that. After the motors is running it is basically a suction after that.
So I have taken the gas line off the fuel pump connected it directly to the hose that goes to the carb . It ran . But at that point all testing had to stop
When I realsied I had other issues with fuel system delivery. That is why I am replacing it all.
The one thing I have found out is if you buy cheap you get cheap. So I want to get out on the water with one of the 3 motors
By this weekend and have some fun fishing with my boys .
I will write again when I start the repairs and give an update .
Thank you all as always
Dale
clemsonfor
Dale
Well the suction comes from those pulses from crankcase pressure. The is not enough suction of fuel to draw the fuel up say if there was no fuel pump?
Crosbyman
"The one thing I have found out is if you buy cheap you get cheap"
agree 100% yet... I try to balance things between cheap and fleeced .
Dalejam
i watched some videos to see about the suction or pressure depends on how you look at it, but most say 1lb, the problem is unless you hook a gage to the line and add a T so fuel can still go to motor when running. you wont feel it if you put your finger over the hole? so out of the three motors i have, none of them create enough that i can feel. then again old cracky fingers from being a worker. but seriously is there any other way to tell on the pulse ?
I do have to get the new fuel line and primer and connector's in. to eliminate a good amount of my issues. didnt realise how much havic it can cause if you are sucking in air through the fuel delivery system.
thanks as always for all the help and information.
Dale
Crosbyman
before blowing $$$$ in suspected air leaks just wrap them up in cellophane tightly to prevent air leaks ... retry .
you must be the unluckiest man in the oldies world at 130 posts ...:)
