1974 Evinrude 70 h.p. motor
iggyw1
Ensign
Hi guys,
I am thinking about buying a 1974 boat in excellent condition (almost mint) and it has an Evinrude 1974 70 horse power motor on it that looks great. Cannot run it this time of year in Michigan, but just wondering if this motor is known to be a good motor or a bad motor in general?? Any experience with this motor? How is it on gas? Any problems to look for?
Thanks for any info you can give me. IGGY
jbjennings
Re: 1974 Evinrude 70 h.p. motor
I have that exact motor. I don't know about fuel consumption since I haven't ran it yet. It's an excellent motor from all my research. The only weak links I have found/been informed of are the difficulty of changing the water pump impeller because of the shift shaft release point (I recommend changing the impeller!!), and the thin, easily-warped-by-overheat exhaust baffle plate. Other than that, they are very good outboards. The 74 is normal, mechanical shift so that's a plus as well.
I will be looking for a pic of your rig if you get it! :)
Home Cookin'
I've had 2 from the mid 80's and they have great reputations. They are easy to work on and mechanics know them.
Sometimes parts are expensive--for example, one of mine had a wiring harness that was only made for a couple years, so little demand, so very expensive.
you can check compression now; a bump won't hurt anything. Also look for black stuff coming down from under the flaywheel; that's a bad stator and a bad ($$) problem. After that it's generally obvious or not too expensive.
But any time you buy an old one, budget for a new one!
iggyw1
Ensign
Thnks for your reply. I am going tomorrow to check the rig out. It looks sooooo nice in the photos, inside and out! Even the engine looks great. I am old enough to realize that looks are deceiving. I was just curious as to the reputation of the motor. Thanks!
iggyw1
Ensign
Thanks for your input. I am thinking that the first thing I am going to do if I buy the rig is to change the impeller in the motor. The boat and motor both look great in the recent photos the seller sent me. He is asking $2,500 for boat, motor and trailer. New bearings & tires on trailer too. The boat is a Thunder Craft fiberglass boat. I am going to look at it tomorrow morning. Hope it is as great as it looks!
Thanks!!
eavega
I ran a 1976 Johnson 70 HP for a few years on a 15' fiberglass tri-hull. The motor was very easy to work on. 1974 will put you past the hydroelectric shift era for Johnson/Evinrude, so you should be good to go there. The shift Shaft screw is not any more difficult than other configurations. Its located in an odd position between the carburetor and starter. If I recall correctly, the easy way to get it off was to remove the air box. 6 extra screws need to come out. The problems I had with the motor were mostly electrical/spark related; the rectifier was not functional when I got the motor, and the power pack went at the end of the first season. Luckily enough there are very well-defined troubleshooting procedures for the CDI ignitions, and parts are readily available (although as a previous poster mentioned, some can be a bit on the pricy side). The 1976 model years had a unique problem with mid-range acceleration, but it was supposedly limited to the 1976 models only. Be very careful about replacement parts; some of the parts are interchangeable with similar motors up to the mid-80's some are very unique to the 1973-1978 models. I believe in 1978 there was a change in the lower units, and that is where I started to find a lot of incompatibilities. As to fuel, I would run that boat 4-6 hours at a time at high cruising speed/WOT (pulling tubes for the kids or running from fishing spot to fishing spot all day long) on 6 gallons of gas. I would estimate it would burn through about a gallon an hour if run right around 5K RPM.
I would be more concerned with a 1974 fiberglass boat. Make absolutely sure you are not looking at a fiberglass shell around a rotted wood core. Check the transom for any flex, check around the seats and at the base of any livewells or storage boxes. $2500 is too much to pay for a 1974 motor, a trailer, and a restoration project hull.
Good luck.
Rgds
Eric
jbjennings
I have to admit, Eavga was right, the shift shaft wasn't that hard to reinstall. It' looked a lot worse than it was!
I'm anxious to get my old 70 horse on the water......
Hope you find a good one.
JBJ
