I have a question for you gentleman. I have a used replacement stator for the motor. The ohm reading on this one is good.
My question is the 2 yellow sensor wires are the same color. I don't see the yellow gray. How critical is the order of the wires to the terminal block?
In my wiring diagram it shows the yellow going with the yellow from the rectifier on the terminal and the yellow gray to the gray that goes to the tack.
Can this make a difference in the way it's hooked up?
How can I tell if they or hooked up wrong?
Also had to buy another timer base. On the second lead had no reading on my ohm test. The new one reads good.
Thanks for your help.
Have a great Friday.. May the eagle fly.
