steveclark99
- Joined
- Aug 2, 2021
- 5
I had very few problems taking the lower end off the motor after i discovered how to take unhook the shift rod. Now I have completed rebuilding the water pump in the lower end and as tried to reassemble it, I slipped the shift rod and driveshaft through the holes. I can't get the gear case and exhaust housing any closer meeting than 1 1/2 inches. The shift rod is coming through the hole and I have turned the propeller and motor to assist in flywheel/driveshaft alignment. As I look at YouTube do it yourself videos this is supposed to be a very easy step so I must be doing something very wrong.
Any suggestion would would be really appreciated!
