1974 evinrude V 4 cyl
MCCAS
as I don't have the book on it yet, does anyone know what the small housing is that connects the water jackets from the two banks of cylender heads are? I think its the thermostat? not sure..Its about 3 inches long 2 inches wide and 1 inch high, between the two sets of cylenders..
OBJ
Re: 1974 evinrude V 4 cyl
Correct MC. This is the T-stat housing. Contains two T-stats, bypass valves, seats and what not. One T-stat per head. Yes, one head can het hotter than the other. You should also have a temp switch in each head for overheat warning. The temp sw's. on yer engine will have a wire coming from them and into the engine harness.
MCCAS
thanks buddy,will have the book on it soon,but with all the bright minds on this site like yourself, who needs books. :p
ledgefinder
Ensign
Just one thermostat and one temp sensor (starboard) on the 69-77 V4s.
