So, I'm working on prepping for some gel coat for my restoration, but I'm worried that my boats hull is paint. I know that gel coat doesn't stick to paint very good. Is there a way that I can decipher if my hull is paint or gel coat?
Set an acetone rag on the suspected paint. Leave it for a bit, if the surface starts to wrinkle & lift = PAINT. If it doesn't it's likely gelcoat......
Ayuh,.... Is it original,..?? What makes ya think it's paint,..??
Post a picture...
Intriguing... 6mo you've owned it 'new' to you or it was factory/showroom new when you bought it?It's original, but I've only had it for about 6 months. I think it might be paint, cuz I'm taking some pin-striping off and the supposed paint is just chipping really easy.
You can see the spot above the pin-striping that definitely needs work. It's like that in a few spots on the boat.
