1974 Glastron V-179 Starflite Fuel Sender Info Needed
oldfarmall
Hello-
I have a 1974 Glastron Starflite V-179 boat. I want to replace the fuel sender unit in the tank. Will the universal units work with my OEM fuel gauge? I think the universal units operate from 30-240 ohms. Just not sure if this will work with the oem gauge, as the current sender I cannot get an ohm reading from as it is shot. Thanks in advance!
-Jesse
jhande
Once you adjust the float for your tank it "should" work.
Johnrechd
Hi Jesse, I have the same boat and need to get my fuel gauge working. Did you end up getting this fixed? Mind providing info on how to access it and if a universal sender worked?
