Wishiniwuzfishin
- Joined
- Jan 17, 2010
- 415
I was just running my 1974 Johnson 115HP in my drive on water muffs. I didn't see any water coming out the upper exhaust ports(doesn't have peehole). I ran this motor in the spring and remember water spray coming out the upper exhaust holes. I was having trouble starting the motor in the spring(it was still cold here then) but when I did get it running there was a water spray out the exhaust holes, as it should. Left it sitting and used my small fishing boat all summer and now tried starting the 115 again. It started up real easy but no water spray. I did some searching on here and found some posts that made it sound like (if I understood correctly) if I unhooked the 2 hoses in the pics (where arrows pointing) and hooked motor up to muffs the water pressure should force water out the 2 outlets where the hoses are unhooked. I tried this but no water came out. Should water have come out?
2nd pic just shows a better overall view
