1974 Johnson Runs Great then has Problems
msms
I have a 1974 Johnson 85 that starts up and runs fine for the first 10 minutes or so....then it loses it's top end. After that it just crawls along at barely above an idle and has trouble starting. No smoke or anything else obviously visible. And it seems to do great up to the 10 - 15 min mark. Any ideas?
HighTrim
Re: 1974 Johnson Runs Great then has Problems
(Compression & Spark Test)
(J. Reeves)
1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi (somewhat less on the smaller hp engines) and even on all cylinders.
2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On magneto ignition systems.... and also the Battery Capacitance Ignition system OMC engines from 1968 to 1972, set the gap to 1/4". On the solid state OMC ignition systems from 1973 to the present, set the gap to 7/16". The spark should jump the gap with a strong blue lightning like flame..... a real strong blue snap!
If there was no spark, on engines from 1973 up, disconnect the RED main electrical plug at the engine. Remove the s/plugs. crank the engine via the starter solenoid (jumper bat term to small 3/8" term nut, not the ground nut) and observe spark. If spark is now okay as stated above, the usual cause is a shorted ignition switch.
If the above checks out as it should, and the engine dies out when throttle is applied or won't idle, it is usually due to one or both of two things. The carburetors are fouled, in which case the cure would be to remove, clean, and rebuild them..... or the timer base under the flywheel is sticking which would result in a retarded spark. If the engine will not fire/start at all even though you have the proper spark and compression, it's usually due to fouled carburetors.
To check the timer base for sticking (Engine Not Running), spin the prop to align the shifter dog with forward gear and while doing so, put the engine into forward gear. Now, while watching the timer base, slowly apply throttle clear up to full throttle. The timer base should move smoothly all the way up against the black rubber cap that is atached to the end of the full advance spark setting screw. If the timer base sticks, find out why and correct that problem.
Usually any sticking of the timer base is caused by one of the four retaining clamps being slightly too tight. Putting a very thin washer under the clamp cures that problem. Some boaters use a thin screwdriver to bend the clamp upwards slightly but I prefer the thin washer. The sticking can also be caused by having a faulty stator start to melt down, resulting in a sticky substance dripping down on the timer base nylon retaining ring.
Sounds like one of your coils or sometimes known as powerpacks is arcing to the block. Check it at night by taking the cowl off and looking for an arc. I don't know for sure if your 73 has them, others on here will know for sure. When the wire gets bad or the coil cracks it arcs to the block so you are basically running on one cylinder.Is your motor getting fuel? If you were fuel starved you would be able to squeeze the primer bulb and it would take off again. Pull one of your plug wires and see if it starts. If it doesn't then I would replace that coil. If it does start then pull the other one and see what happens. The weak coil might only break down at higher rpms too.
msms
Thanks HighTrim. I'll start at the top and work my way down.
bigbob_FTW
Mine was doing this too. Turned out to be hairline cracks in the coils. as stated above, try running at night and see if you get any arcing.
