1974 merc 65hp no fire
85 BOMBER
Greetings all! I have a 1974 merc 65hp 3 cyl model no 3815866. It is not getting power to the coil. I have no voltage coming out of the lower (green) terminal on the switch box. Does this mean I have a bad switch box? Engine spins over fine, but no spark from coil. Thanks for any input!
stormmnv
Re: 1974 merc 65hp no fire
go to www.cdielectronics.com they have a full test proceedure on line.
they also have good replacement products that you can order from iboats...
coolbri70
make sure the coil has a good clean ground, then check to see if it is getting current, if it is not check where it comes out of the switch, if no current found there check if the switch is getting current if it is then its likely the switch if not check your fuse then battery connection?
