1974 mercruiser
matthew hardman
I have a 22' cuddy cabin with a straight 4 in it I want to put the biggest motor in it that the lower unit will match up with what size is that and what do I need to do it :confused:
Don S
Re: 1974 mercruiser
With the gear ratio in the drive, you will have to stick with the 4 cylinder engine. Your exhaust pipe that hooks to the transom shield is also setup for a 4 cylinder.
Re: 1974 mercruiser
By Regearing the outdrive,<br />You Can step up to a SBC........<br /><br />Or, Any Other V8 that was Ever installed in front of the Mod.1 drives.......
matthew hardman
Re: 1974 mercruiser
thanks bondo do they make a kit for that and where can I find it how hard would it be
Don S
Re: 1974 mercruiser
The outdrive upper gears would have to be changed. You would have to get a Mercruiser dealer to do the job, it requires reshimming the new upper gears with special shimming tools.
Don S
Re: 1974 mercruiser
You will probably have to add motor mount pads to your boat also, as the 4 bangers had the front mount and the V8 or V6 engines had side mounts.<br />While all this changing can be done, there is a lot more to it than meets the eye.<br />It would probably be cheaper in the long run to find that size boat with a V8 in it already.
Re: 1974 mercruiser
Ayuh........... What Don Says.........<br /><br />There's No Kit......<br />Ya gotta go out,+ Scrounge the parts to put it together.......<br />Or, Better Yet,<br />Go buy an Old Rotted Out "Donor Boat" to junk out,+ Then you have All the Little Pieces that co$t a Ton of Money $$..................... ;)
