bassboy416
Thread starter- Joined
- Jul 9, 2013
- 79
So.... Bought a 1973 kona skier with a 1974 mercury 1150 in line w/ trim. Boat has 2 seperate issues (at least I'm pretty sure theyre seperate). Boat has always been hard to start for the first time each outing but runs and starts fantastic once warm... last time I took it out the engine would not start... It cranked without any sputter or even trying to start... I pulled the plugs, cleaned them (Surface Gap plugs which weren't really even dirty).... I threw some premix in the spark plug holes and she started up and purred like a kitten... Is this a carb related issue? not sure... Runs great at wide open throttle and all speeds.. Idles excellent as well... Boat does great when you nail it too unless you're towing a wakeboarder then if you go WOT too quickly it will stall out... but it does not run rough whatsoever... Boat was winterized 2 years ago by a mechanic but not sure when the last carb clean was... Anyway... The second issue is the big one... When I bought it, the battery was fried... Bought a brand new marine battery but noticed that the battery cables were in poor condition (missing insulation and having electrical tape on them in spots... They look sketchy... so... it has always had a starter delay meaning that when i turn the key it clicks...... waits a second..... then engages the starter... well the last outing I was pushing the limits of how long I should crank my motor to start it and the negative cable started melting the electrical tape on it and smoking... anyway, we took it out and the delay seemed slightly worse but it ran great for about 3 hours... then in the middle of the lake we had been sitting for about 30 minutes and went to start it and the starter moved up to engage the flywheel but didn't seem to have enough power to turn the flywheel.... I tried manually starting with a cord but with no luck... got towed in.. but now it clicks... engages the bendox spring and turns the flywheel like one tooth (not even a quarter rotation and wont go). The engine is not siezed. I am a construction worker who is mechanically inclined but also not a boat mechanic and with a busy schedule... Called a shop for an estimate on a carb clean, battery cables, starter, starter solenoid, impellor and it was 1000 bucks... I've read into this and believe that it may be simple enough that I could tackle this project on my own but looking for advice... I am willing to spend the 1000 dollars but would much rather have 1000 dollars of parts than 400 in parts and 600 labor.... any help is MUCH appreciated!
