Just rebuilt carbs, fuel pump, and replaced fuel lines and primer bulb. Only had the boat for about two weeks finally got it started yesterday but it usually takes two people to start. (one cranking while the other feathers hand over middle carb) some one has replaced the choke button for a switch once and when choke is activated I can see space between the disc and carb not a lot though its just not sealed. Is that normal? Once started though it'll start right back up, but it's a nightmare if cold. Right now when I try to start I have gear lever in neutral, cold idle all the way up, put some fuel directly in number one cylinder, and have someone hand choke the middle card and it eventually starts. Any advice??????
