Needtwofish
Thread starter- Joined
- Apr 13, 2016
- 4
I need help, I have a 1974 Mercury 1150 that was given to me and had set for 2 years. The boat is great but I need help with the motor. At first it would just crank and crank and crank and not nothing. Upon investigation I noticed that the wires coming from the stator had corroded off. So I purchased a new stator, rectifier, and spark plugs and installed them. Cleaned the carbs as best I could, put fresh fuel with the proper mix in. Checked all other wiring and tried to start. It will try to fire but it just will not start. I called the local boat shop they recommended to try a little either. Still the same thing happens. It will try and start but nothing. So I called the boat shop back and they recommended to put some sea foam in the fuel and just keep trying. They said it should eventually start. This does not sound right to me does anyone have any suggestions on what I should do next?
