Re: 1974 Montgomary ward 10hp help
Hey, I'm in the same boat...I just got a M-W Sea King 10hp and need to replace the pulley spool. Thanks for the advice, I'll check with the Merc dealer.
I bought this on craigslist.com from someone who had it in his garage since 1974. It had perhaps 1 or 2 tankfuls of gas run through it. But, all the nylon plastic parts on the starter are age-cracking.
I replaced the fuel pump diaphragm and impeller, took the carb apart and cleaned everything inside, and got it running. Then, I noticed the starter rope was fraying. The little black nylon pulley that the rope passes around cracked apart, which scraped the starter rope. The pulley axle is a spring pin. You have to pull the flywheel and ignition plate (held on by 4 screws) so you can then use a pin punch to knock the spring pin down out of its hole. It appears to be a 3/16 (.187) dia pin. I'm replacing the pin with a homemade solid pin that I can replace without pulling the flywheel each time.
It's tricky, but you can remove the starter and re-install it. To install, just need to hold all the parts together while rewinding the starter spring, aligning everything, lining up the bolt holes, and installing the bolts.
Thank You
GlennH
