My boat has dual OMC 165hp engines with stringer sterndrives. It has separate controls, 2 for the throttles and 2 for shifting. The shift "cables" are actually a switch, which consists of 3 pairs of wire connectors (blue/purple, white/white, green/purple). This switch is connected to the control housing and the actual control arm. Moving the arm moves a central shaft in the switch, which seems to make a connection at one of the 3 different pairs of wires. What I need is the part number of the switch itself, as one of mine has become intermittent, when shifting in reverse. It is definitely the switch, as the VOM (set to ohms) does not reliably show the switch going to near zero ohms at each position...
So what is the part number for that switch and what is that particular switch called?
