1974 reinell cuddy restore
Nice looking job, hope you don't have any issues with it. The strongest places of the tank are the edges, and while support looks good, it is only supported in the middle.
fetch
fetch
fetch
froggy1150
Ensign
The 4 corners are supported by 8 inch strips about a inch in from the edge of the weld fore and aft. The 4 middle supports are about 18-20" long. before I wedged tank In on sides I could stand on corners and try to rock it and it would not budge
froggy1150
Ensign
Just about got all my deck glassed on the underside and prepping to glue down. What's better, stronger, eaiser? Pb or 5200? Don't know the average strength of pb but I think I remember the 5200 having a pull strength of 3 tons per 4"square.
chevymaher
PB is pretty strong despite the rumors. My boat had no cloth in it from factory. It was a chop gun. It lasted 30 years. So it was basically made from PB.
1708 is 6X stronger than chopped stand. But the chopped strand is no punk. I use it for all kinds of structural things in auto bodywork.
I used PB as teenager to fix rust in a wheel well. Car got hit in the side. tore good metal away from the car. It was attached to the fiberglass. floating in mid air. It obviously has some stuctural rigidity. More than the surrounding metal had.
So take it for what it is worth. it is stronger than you will ever need it to be to do that.
kcassells
Yup I laid my deck with hairy pb. I had no reservations in regards to strength.
froggy1150
Ensign
Where to put holes for foam? I have read/seen both ways. I understand each cavity will have multiple holes or vents. My specific question is to put hole down low, pour foam, and plug hole when it gets there and then let rise OR drill hole high, let foam solution flow downhill, hope it gets to lowest point of cavity and rise from there.
kcassells
So boat is on a tilt. ea. cube has a low hole and then a high hole. Pour is in the high. Comes to the low then forces itself to the high hole. They vent off that way.
froggy1150
Ensign
Here is the drain for the area where you step down into the cuddy. This was a point of failure from before. There was no place for water to escape from this area. There is a drain at the bow and this. When I put this part of the deck down I put a paper towel roll to keep area Clear while foaming. Afterwards I peeled the roll out and put 1708 in hole to seal foam. During final assembly I will also coat everything/fill cavity in 3m 4200 as a second barrier to keep foam dry
froggy1150
Ensign
And I got foam.... not beer foam either! I used to camper jacks to tilt bow up. It's hard to tell but hitch is about 5 feet up in air. Couldn't go higher cuz rear pair of wheels were coming up and tail of trailer was dug into ground and it was getting side to side tippy. I left these little "vents" in the tabbing to allow air to escape and let foam get to edge of hull. Seemed to work well. Got good fill and almost no waste. 2 football size chunks and some little scraps. Used 3 2 gal kits and got it all in at about 75-82 degrees
froggy1150
Ensign
And when you are done sanding...... sand some more!
deck is sealed so now I can rest easy without worrying about wood getting wet. Only had one issue laying 1708. Doing by myself the big section over the tank. It was layed a little crooked and tried to fix it and made a wrinkle with a few bubbles. Easy fix. At least it's down before it got cold ( today it's about 60 but suppose to get colder over the holiday) now to gel coat.
froggy1150
Ensign
Been awhile since I updated. Well the floor is white gelcoat! Was 45 deg out so I turned on the one heater by the bow and walked away to let the hull warm and came out to 107 deg.... oops. Didn't even fire up the propane one. It's a 1950's Era 240v 3 phase that I rewired single phase. Draws 32 amps o. A 200 ft so cord. Puts out about 700 deg f. Now that's toasty:flame:
Looks good and that's some heat. Might be a tad spike in the electric bill today
froggy1150
Ensign
Used treehouse/"work platform" to gravity feed Lube down cable. Worked back and forth til oil came out clean. Smooth as silk!
froggy1150
Ensign
Cuddy prefit and now working on the cabin layout. 2x4s are so I don't have to screw into deck
