Watermann
- Joined
- Jan 12, 2013
- 13,857
Set the meter to DC and it should read 12.6v resting when fully charged if a cell is bad then it will be below 12v, When running the meter will read above 13v if charging.
Fuel will run out of the carb throats when the motor is tilted. Before I was referring to the idle air adjustment screws on the front of the carbs, if you have the air box off you can see them.
