1974 starcraft 16 ft super sport
barato2
Re: 1974 starcraft 16 ft super sport
yeah, no kidding. major progress, esp for winter.
anderso8623
Fisher man, I'll PM you about those bow rails.
155k Btu will allow such progress. I thought I was behind. Its been a few weeks sense last time I posted.
anderso8623
Sorry I have been distant; Thanksgiving and Christmas have gotten the best of me! I am about to flip this boat and start the stripping. I am looking into the sharkhide and am seeing reviews that say it makes a dull finish after applied. I am looking for the high gloss finish for the hull, should I be looking elsewhere for a different sealant?
dozerII
Hey anders, check out Caswell Plating.com and Inmotions thread on his Falcon. He is already using the Caswell system and I will be as soon as my kit arrives. I also found the Shark hide system not a shiny as we wanted on the Naked Lady.
anderso8623
Got a nice warm day to clean out the inside of the boat. Goop toworrow.
64osby
Yea it hit 47 here today, nice day for projects. Back to real Winter next week.
Looks nice.
anderso8623
We hit about that here. I did not want to clean the inside and have a sheet of ice to melt after I was done. Heater or no heater, I still have to clean it outside.
anderso8623
IMG_20131229_165449_561.jpgIMG_20131229_165437_098.jpgIMG_20131229_165429_581.jpgIMG_20131229_165420_536.jpgIMG_20131229_165359_466.jpg
I know, nothing too exciting but got the goop on. Soon as it drys I'll do a second leek test. Then flip and strip.
anderso8623
There were a few spots that had excessive pitting. Cleanedthem out as best I could and filled in with goop. I'm hoping that should fix the issue.
fisherman58
what is the goop your using I will be doing my 71 ss probably next year mine is all original floors
anderso8623
The goop I use is called "goop" and is made by coat-it. They come in increments of 2 pounds. So 2#, 4# and so on.I used the entire contents of my 2 pound kit. Any bigger then 16ft I would go with the 4# kit.
anderso8623
A 2# kit comes in a quart paint can but is only about half full, and a pint can of hardener that is about half full as well. Total amount after mixing comes to just shy of 3/4 of a quart. I like smaller increments of it because the mix ratio is 7 to 1. With the smaller sizes, I am not worried about mixing it right or it hardening before I have coated everything.
jbcurt00
I think it's actually a product called Coat-It made by GOOP:
anderso8623
so I will need a steering cable as my current one has cracks all up and down the casing. How long should I be looking at?
jbcurt00
You going all new steering: Wheel to motor?
anderso8623
the only thing I am saving is the wheel. I attempted to get the cable off the arm that attaches it to the motor. NO DICE! I think it is a rotary style. Ill try and post a pick of it.
jbcurt00
You need to pick a system 1st, then measure per their directions, if you're replacing everything from the wheel to the motor. Depending on what system you use, you might get luck & be able to reuse the transom clamp assembly that's grabbing the steering cable in this pix:
attachment.php
And make sure the motor connection will work w/ your motor.
Most steering system makers have the instructions for measuring for their systems online.
