WanderingWolf
Thread starter- Joined
- May 5, 2021
- 3
Hi all... New boat ( First one for me!) that is a total mess and I'm digging in and trying to start the repair process. Bought this last summer for $100 and am somewhat using it as a testbed as I just completed boat school and am now an ABYC/NMEA certified marine technician/electrician. Hoping to make a decent little crabbing/shrimping/tooling-around boat for the waters here in the PNW.
1. Tips on how to change the engine belt? I know I have to block/jack the motor and remove part of the mount. Just looking for any helpful tips.
2. How to find new/refurbished parts? Have a couple of parts (#60372, #47587) that need replacing and the local Mercury shop said they'll be impossible to locate due to age.
3. Tried to engage my throttle today (Which I'd done previously without issue) to test if the motor would turn over via the prop, and the handle broke off. Actually, the splined piece that comes out of the assembly behind the side panel that the lever attaches to broke off. It's toast, no repairing it. How do I find a replacement? Used, refurbished or new? Do I have to drill out all the rivets and remove the entire side panel to access this for repair/replacement?
Should I seriously consider just junking this motor and switch over to an outboard (thinking a 90-115 should be plenty)? I know that's a lot of work itself plus the cost of a (used) outboard which still isn't gonna be cheap. But, I am worried about being able to keep finding parts (that aren't used) as they wear out (they already are), the age of the motor, the condition which is still unknown, and the amount of rust (large chunks and flakes) I've already seen inside the cooling system.
Outboard question; If I do switch over, do I need the trim tabs on my boat now or are those only needed with the I/O? They're aftermarket and seem to be in decent condition still.
I bought a lot of tune-up parts this week, but after that throttle lever broke today and learning I have to take apart the motor mount to change the dang belt, I'm feeling a little defeated with the motor and am leaning towards tossing it and starting the process of redoing the boat with the plan to add an outboard...which would free up some real estate inside the boat and allow me to add some storage.
Talk me into keeping the 140? Talk me out of it? Tell me how to fix, repair, and find parts? Tell me I'm stupid for buying a $100 hole in the water? Send me memes to lift my spirits? Drink a whisky with me?
Okay okay...seriously, looking for help, tips, advice, opinions, whathaveya. Thanks in advance!
