1974 Starcraft Chieftain 18' OB refit
Status
Not open for further replies.
sprintst
Re: 1974 Starcraft Chieftain 18' OB refit
Looking good man. Get used to the compliments. These cool old boats have great lines.
MichaelP
Outside hull painting is done. I have a few small sags to tend to later. The first coat of that white on the bottom was so hard after a week red skotch brite barley touched it!
Yes, hoping to deflip next weekend.
The compliments never get old.
Rghammond
Great job on the paint. You did the old girl proud, she's bound to get some wolf whistles on the water:D
Woodonglass
Honorary Supreme Mariner
MP, you did yourself proud on the paint job!!!!
MichaelP
Wolf whistles...Too funny.
Wood - Got a few small sags in the black that I might need coaching on to remove. I'm no body man but I have a DA and automotive buffer (don't ask why).:confused: Going with your rusto formula for the top sides.
Well here she is in her new party dress wearing no tape. Overall I'd say its a 10' paint job the pics make the texture look worse than it seems in person. That yellow frog tape made much better lines than the green so it will be my recommendation going forward. After these shots we masked the sides again to paint the splash rails with rusto chrome.
boatnut74
Looks great!!! You got the worst part behind you now. Should be smooth sailing from here on out :D.
MichaelP
Thanks BN. Everything else will be a piece of cake compared to this. Next is replacing the bunks and removing globs of old paint on the trailer. Picked up the materials yesterday. Factory used 2 x 6 PT so I'll do the same unless its a mistake.
jasoutside
The black white combo is sharp!!!:)
Woodonglass
For sags, and runs, just wetsand with 320grit. Go easy and be precise.
MichaelP
Some progress...The rub rail trim is done and all the paint is definately hard enough for a flip. Today a buddy tweeked his back so I need a replacement buddy. Been collecting etch primer bare metal primer and white rusto for the topsides. Thinking of a 3/4" or 1/2" wide pinstripe between the black and white. Seat order is in at Cabellas and getting ready to do a hardware order. Weather window for painting is closing fast here.
The trailer has new bunks and I scraped off all the old paint drips the PO left behind. When I find my wire brush I'll finish it. Thinking of replacing the bearings but its scope creep.
Thanks for the advice there Wood but the reality is that if your close enough to spot these small sags your also going to see small dents here and there. I'm calling this a 10' paint job. Not so much because of the paint job but what I started with. (Never noticed most of the imperfections till the black went on.) Calling it good for now and moving forward.
jasoutside
Aw sheesh, I can't see any of your work there Michael.
You could check craigslis or eBay maybe. Kinda hard to find sometimes, bit rare ya know.
yooperangler
Sounds like a lot of progress but I have the same problem as Jas (hmmm that sounds bad:rolleyes:) can't see it.:)
Just fill a cooler with beer and stand in the yard staring at the boat if You have nieghbors nearby it won't take long :D
MichaelP
Well after checking craigs list and standing one the side of the road wearing a sandwich board near a cooler of beer I still didn't attract a replacement buddy.:facepalm: But my buddy is feeling better and wants to help. Hope to get a couple more this week.
I'm all ready to deflip but using this time to recondition my rub rails by covering with vinyl paint. I tried a couple spots and it seems very durable. Also looking for pin striping (1/2" silver) to go between the black and white along the water line.
Cradle is modified to carry her right side up. Next is painting the interior and top sides so keeping it in tha garage at night is a must since its getting cold. 37? Sat morning.:eek:
Dug out the flotation foam I stored under a tarp. Turns out it made a nice mouse motel 6. Had to clean every piece.:mad: I have 20 cu ft so it will be more than enough.
It may seem premature but Cabellas was having a good sale on seats so I snagged them and some pedistals.
Eyeballing that splash well. Gonna cut down a bit.
Rghammond
Have you used that cradle yet? I take it you roll the boat top towards the plywood, right?
MichaelP
Haven't flipped yet but when I do it will rest near the center of the hull. The carpeted bunks fit between the strakes. I made it up side down on the hull so it takes the true shape of the hull. and yes, the front of the boat happends to be toward the far side in the pic (plywood side). Hope this answers your question.
Got all the rubrails cleaned and painted last night.
yooperangler
Good to hear Your buddy is feeling better MP hope You can get her flipped soon. Looks like pretty much the same seats I have just different color nicer pedestal though but bet I have more of em than You :)
Rghammond
Great idea, let me know how it works. I won't be getting back at mine til this weekend but I may try that, thanks
MichaelP
The cart worked great to carry the boat up side down. Now it's modified to carry it right side up I'm pretty sure it's going to work fine. Just wish I had the material to make the bunks longer than 3' but it should be ok until I add too much weight.
Last night I installed the rub rails and pin stripes along the water line. Just have to get the splash rail end caps on and the hull is 100%. By the time I was done it was too dark to take pics. Now its pouring out and weather is supposed to be iffy through the weekend. More to come soon.
boatnut74
The darn weather always holds up progress. It's 38 degrees here right now, I'm not to motivated to do anything on mine at the moment.
MichaelP
Rounded up nearby skateboarders and had a flip in the rain:D. The new cart works perfectly and I can move the old girl around with one hand.
Had to try the new belly tank and that fits fine. Got the last one like it at GLS. It's bowed inward quite a bit on the bottom but they gave me a pretty good kick back. Thinking about pressurizing it and heating it with a salamander. Thoughts on this would be appreciated.
Sample Starmada hat came in too. :D Plenty available.
Status
