Re: 1974 Starcraft Chieftain 18' OB refit
Experimenting with 4 different chemical strippers so far and next up is the Kleen Stip in the orange can per Lakelovers suggestion. Its too bad that all the paint is in really bad condition, it's all gotta go! 4" wire wheel works faster and my 7" grinder with a sand paper wheel works faster yet but you've got to be carefull with it.
Got the new transom cut and found some free glass to sandwich inside. This is really heavy mat that's used for protecting items from weld spatter. Its slighly used and dirty so I wiped it down with Xylene. This is so thick I/m wondering if I can wet it out. This is what I call a "Glass-in-Wood Transom"
. Did a dry fit in the boat and it goes in fine. I did grind some small tapers along the outside edges to give more clearance on either end. Hoping the epoxy doen't biuld up too much thickness. Have epoxy but just need to pick up mixing bowls stirrers etc before hitting it.
One the pics here shows the remains of the Starcraft logo that someone painted over.
Old transom got the viking funeral last night like the rest of the wood I pulled so far. Damed thing didn't burn but just laid there cooking all evening.
