Holiday16/85
- Joined
- May 30, 2015
- 14
1974 StarCraft Holiday Mercontrol - Engine runs with key in OFF position. Help please?
Hello, I'm new to this boat and recently replaced the dash board. I had to unhook a couple wires behind the dash that go to the sump pump and a forward mounted spotlight the previous owner installed. I re-installed those wires guessing what posts on the aftermarket switches the PO installed. Had a few major 'sparking events' back at the battery tonight when I fired up the engine. I ran the boat last year with no problem starting and shutting off. Now, after the winter sitting in the yard and the dash replacement, the engine still runs when I turn the key to the OFF position. Can anyone guide me towards what to look for to correct this please? I also installed a tach in the new dash, plugged into the Mercontrol front tach plug ... not working at all. IS it possible that I connected wires under the dash that are creating this 'run in OFF position' situation?? Thanks for your help please guys.
