1974 Volvo 270 engaging Forward
EricKit
Looking for solution to this problem: My boat will not fully engage forward, other gears work fine.
Details on the problem known for sure:
1974 Glastron
Ford 302 Motor
Volvo 270 I/O
Engages reverse and spins nicely. When boat is turned off I cannot turn prop the opposite way it wants to go (Which is good).
Neutral works
In forward prop spins slowly. Spins faster as throttle increased, but much slower than it should. It does not grab, I can turn prop backwards in forward gear.
When removing upper unit case to see gear rod, I removed the rod and manually shifted gears by turning the knob: The outdrive properly engages reverse (Prop only turns one way). In neutral prop turns both ways. In forward prop spins easily one way, and some resistance the opposite way, but not much.
This information made me think it's either the cone clutch or gear housing in the upper unit. It's hard to find parts for this boat now, so I'm hoping not.
Information that I'm not so sure about because I did not own it yet:
Boat properly engaged all the gears the last time it was in the lake.
While it did run ok last time, there were some cracking in the drive bellows which was repaired. The mechanic removed the outdrive to do this. He then reinstalled the outdrive.
I hope that because it (probably) worked last time, that the problem is something small in the upper unit or with the reinstallation of the outdrive. I kind of doubt the second reason because I manually turn the gear knob in the upper unit and it doesn't work still
I hope this is enough information, please let me know if you need to know anything else, thank you!
TowRoper
Re: 1974 Volvo 270 engaging Forward
did you already check for a spun prop hub?
EricKit
I did not check for a spun prop hub. I thought that because reverse engages, it could not be a spun prop hub. Please tell me if I'm wrong and I'll def check for it! Thanks.
bruceb58
Honorary Supreme Mariner
Hard to believe it could possibly be a prop hub since you can spin it backwards by hand in forward and not in reverse.
TowRoper
I'm just thinking it could be, if it was spun hard in one direction the rubber may have gotten folded over if you know what i mean, and just enough there to feel tight? besides its a free and easy check right lol
EricKit
'Yah, I'll def have to check that out.
captmello
From the way you describe it, the boat worked fine, you brought it in and had the bellows replaced?
Now it's not engaging forward?
Sounds like something happened to it while in the shop.
Usually there is more wrong with the outdrive than just a torn bellows. what other work was done? Was it a reputable shop?
proxyx
Banned
looks like shifting problem, may be due to faulty installation if ok before, foward should lock one way and turn in the opposite, usually what u have ppl have with reverse... have mechanic inspect it, reinstall the drive and check/adjust shift cable
EricKit
Well the forward gear was broken. He's replacing it for around $325 total (including parts). I figure it's important to post solutions to the problems.
system-f
I love seeing solutions to problems. It stinks when you search for the exact problem you have in a thread and no solution is posted.
Thank you
