Re: 1975 135HP will not idle less than 1100rpm
I interpret that as meaning I do not need to get the leaf assembly gaskets unless I replace the assemblies.
How the heck do you put that much pressure on the bolt without it flying out of the hole and creating some really messed up knuckles?
The manifold comes off without doing anything to the reeds and the reeds are easy to examine/check in place. I cannot think of any good reason to remove them unless you find damage or are going to change the reeds.
If you take the reed cages off you have to be very careful in replacing them so that the screws don't come loose and get ingested; if that happens, you will have much more work to do.
The outer holes on the flywheel are blind, about 3/5" deep.
