you can either do a transom elevator or a jack plate. we are talking about a 10 hp, so a transom elevator is the right solution. it is taking 4 pieces of 1 1/4 inch aluminum angle, sold at home depot near the screws and nails. you put a 2x6 on top of your transom thru bolt it with 4 bolts, then thru bolt thru the transom. i would use 18 inch pieces of aluminum angle. so you need 4 pieces of angle and 10 3/8 bolts& nuts, 20 washers 10 lock washers. get it mounted set the motor and go boating, safely.
