1975 25 HP Johnson Problem shifting after re installing lower unit
EMW73
I dropped my lower unit and replaced the impeller and then reinstalled the lower unit and now Im having trouble with grinding when trying shifting into forward. Also sometimes I cant get it to shift into reverse at all. What should I check out first? Any help please.
boobie
Take that little cover off the side of the motor again and make sure you have the shift linkage put together correctly.
