1975 25hp evinrude compression
amonk
i did a compression test on my motor and it came up as 100 in one and 70 on the other is this ok and will this effect my power when i accelarate
tashasdaddy
Re: 1975 25hp evinrude compression
suggest:
Decarb
i would do a decarb, then if it did not come up, the head gasket.
Decarb, take a can of seafoam put 3/4 of it in the gas tank, with only 1 gallon of premixed gas. put the rest in a spray bottle. start the engine, and let it come up to temperature. then remove plugs, and them some real good shot of seafoam into the cylinders, replace plugs, let sit 15 minutes. restart, and spray the rest of the seafoam into the carbs, so the the motor almost stalls, wait and repeat until the seafoam is gone.then take for a wide open spin. then put in new plugs, ad premixed gas to the tank, and take it for a wide open throttle spin. it is going to smoke like a house on fire, during this process.
afterwards compression.recheck
amonk
thanks heaps i will try
marinemech1
Please recheck and post compression numbers.
Wayne
