livelyankee
Thread starter- Joined
- Jul 7, 2006
- 25
Sirs: My 1975 40HP electric model runs great sometimes and suffers fuel starvation sometimes. The starvation is not relieved by opening the tank vent or pumping the bulb but is by use of the choke. Filter is not plugged. Carburetor has been rebuilt. Problem seems to go away if the engine is turned off for a minute or two---I have no idea what I do to eliminate the problem.
A friend suggested b ad quick-disconnects so I check the flow thru them by unscrewing the filter and pumping fuel thru the lines---regardless of how I position the connector the flow is generous and no backpressure.
Bad pump?
Bad pump?
