fngboater
Thread starter- Joined
- Jun 9, 2011
- 181
Hi there looking for guidance on carb placement on this outboard. Someone has had the carbs off before and I’m thinking they’re in the wrong spot. Maybe the bowls were put on the wrong carb? I have seen pictures of the triple carb setup and the middle carb has the big nipple coming out of the bottom of the middle carb. On my motor the big nipple was coming out of the bottom of the bottom carb. Are these carbs the same? Are the bowls the only thing different? Anything I should look for when rebuilding these carbs and setting them up? Thank you in advance
