Besegen
Thread starter- Joined
- Jan 28, 2013
- 57
I finally got the motor running on muffs and tinkered with the thottle setting for idle. I ran it the first time for about ten to fifteen minutes. Right off the bat it surged and sputtered around a little then settled in and ran smooth for about ten to fifteen minutes. Then it suddenly started surging, jerking, sputtering for a minute or so then died. I went ahead and tinkered with the throttle adjust a little more and fired it up again. I started it probably 8 or 10 times and let it run til it did this and died. Some times it happened after a few minutes, other times it ran fine for the ten or fifteen minutes then went back to its shaky ways and died. Posting some videos of it running fine and not so much. I don't have a tach working right now either so besides advice on the surging issue, advice on the idle speed here while on muffs would be appreciated too. Thanks guys.
Video one is it running for a bit early on, probably the second or third time I had it running.
