bimmerbit_93
- Joined
- Mar 21, 2009
- 31
The model is 85593E. The fellow I bought this boat from said that the last time he had it out, it ran fine until they started back from across the lake. It would not run at full throttle. I took it out to see for myself and found that it ran fine even at full throttle for about 200 yds., then began to loose power like you were gradually pulling back on the throttle. After pulling back on the throttle, I found that it would run steady at 3200 to 3600 rpm. The motor is on a 1971 15 ft. Larsen. I checked the compression before I bought it and all cylinders are at 102-105 compression. The water seems to be circulating fine; I get spray from both holes out the back. I also checked the spark before starting it and all the cylinders fired consistently. It started immediately at the lake, and ran really well except for the high rpm issue. I also checked the fuel pressure from the fuel pump and it was 5.8 lbs. at the pump. I have read that this should be tested at the line that goes into the upper carb, and it tested it at the pump. Is this inaccurate? Thanks for any help or ideas.
