boxchevyman
Thread starter- Joined
- Mar 16, 2014
- 61
1975 85hp Johnson.
Model: 85ESL75E
Put a generic full bridge rectifier on, wired it up correctly, and checked voltage at battery.
not running= 12.68volts
running= 3.5-12.80 volts
then when I stop the motor after a few minutes the battery shows 12.73 volts
So the net result is the battery charged somewhat. This is very odd to me so I thought I would ask you guys. Also I did an OHM test on the stator.
No wires show continuance to ground on the high scale.
I get 2.3 ohms resistance between the yellows on the low scale.
This was on a cheep harbor freight digital MM.
So what do you think?
Thanks,
James
Model: 85ESL75E
Thanks,
James
