redinferno
- Joined
- Jun 16, 2009
- 9
I have a 1975 85 hp mercury outboard and i finally got it running the other day. I bought it after it was sitting for 3 to 4 years. So first i hooked it all up and replaced the spark plugs and but in the lower gear lube. got it running went out on the lake got about 50 feet and it died. Ok so i brought it back rebuilt the carbs couldn't get it running.. pulled the fuel filter and fuel pump and cleaned up and put all new gas in and replaced a bunch of corroded wires. Now it runs pretty good! But has no power, it does not get up and go out the water and top end is not great. The only thing i can think of is something with the spark or compression? What should compression be at? and if it is bad what could be wrong like something simple as a head gasket? Any and all ideas would be appreciated!
thanks
thanks
