dodgeman67
- Joined
- Jan 15, 2014
- 36
I am trying to hook up my the original two wire omc tach that came with my 1975 Starcraft super sport that had all the wires disconnected. Is the gray wire coming from the terminal strip always hot. I get 12v with the ignition off. I also get 12v from the strip on all the rectifier connections with switch off. Also the only connector that is there to connect to my gray wire has a green wire from the connector to the harness that goes to the controls. I am Leary of hooking it up as I don't want to burn up anything. Also, I tested the tach by connecting it directly to the third pole on the strip with motor running and it worked. Thanks
