I have an older motor that ran OK, (started hard) until I was running in full throttle and the gas line kinked and it died. Now it seems like it floods out and will not run. The carb was taken apart and cleaned, (because there was gas running out of it when chocked). I replaced the plugs and its getting good fire. Now it really does not look like the carb is getting flooded but there is black gas/oil coming out of the exhaust and leaking on the ground.
Any suggestions would be greatly appreciated. Thanks, Phil
OK, I did some searching on here and it looks like I should start out with a new seat and needle right? or is there something else to check?
