ckswanecamp
Thread starter- Joined
- Feb 3, 2011
- 26
SPECIFICATIONS
BORE AND STROKE---------------2 3/8 x 1 5/8
DISPLACEMENT (Cu. In.)---------7.2
IGNITION-----------------------------high tension magneto
MAGNETO POINT SETTING-----.020
SPARK PLUG------------------------Champion Type J13Y or equivalent.
SPARK PLUG SETTING-----------.025
CARBURETOR----------------------Float
CRANKSHAFT-----------------------Forged
BEARINGS (engine)----------------Neddle and Ball
BEARINGS (gear housing)--------Bronze
STARTER----------------------------Recoil
FUEL SYSTEM---------------------Fuel Pump
GEAR RATIO-----------------------13 - 22
PROPELLER TYPE---------------Shear pin - Semi Weedless
PROPELLER DIA. & PITCH-----7 - 4 1/2
STEERING--------------------------180' Pivot Reverse
LUBRICANT (Gear Housing)-----Part No. #951-247
FUEL MIXTURE--------------------3 ounces Motor Oil to One Gallon Regular Gasoline (24:1 of 2cycle Chainsaw Oil is User Recommended )
IDLE SPEED------------------------800 RPM
FULL OPERATING RANGE-----4500 RPM
PEAK HORSEPOWER-----------At 5600 RPM Sea Level Barometer at 60' F.
