1975 eska/tedwilliams 15hp lower unit oil fill
truckintyler
there a drain and a vent, but no fill screw. what is the right way to fill the lower unit with oil. i'm wanting to test out my new ignition
M
mrcrabs
Guest
Re: 1975 eska/tedwilliams 15hp lower unit oil fill
fill from the biggest hole, it should except a standard screw in outboard lube hose, pump or squeeze the lube in tell it runs out the vent, then plug the big hole and use a oil can or syringe to top off at the vent.
truckintyler
ahh ok most motors i worked on had a fill hole. thanks alot
