1975 evenrude cooling issue
cody8543
I have a 1975 evenrude 115hp v4 that's getting hot I have had 2 water pumps install questions I have is I'm fixing to change out thermostats are there any issues with leaving them out only gets run in summer time only fresh water plus this motor doesn't have the p hose goes out threw exhaust can I convert it with a newer exhaust plate that has p hole an will it cause any issues
I think there is only 1 thermostat.----Checked head gaskets and water diverters ( deflectors ) in water jackets?
cody8543
The what I call the water diverting plate on mine doesn't have a provision for a pee hose can I drill an tap for a pee hose or can I just replace the plate with one that has one already an willnthis cause issues if I do this an if I don't run a thermostat will it hurt anything only run in summer in warn water
cyclops222
Remove thermostat ? Engine WILL run too cold. Sparkplugs become filthy BLACK and start random misfiring. Also builds up hard black carbon in the cylinders. Which can lead to PRE IGNITION destroying plugs and pistons.
Stop being a redesign engineer. Find the defective parts.
Mc Tool
You should use a t/stat as an engine running to cold is problematic .....sure you may have heard of others doing it ......but its there for a reason .
No reason why you couldnt fit your own p hose as you describe , Id just drill a hole and put a nipple in it ( like a brass nipple not......😁) . Just gotta remember that this hose will only tell you the water has got as far as the hose , not that the cooling system is fully flooded.
Probly the 1st thing to do is find /figure out how the water flows thru the motor and follow the flow untill you find the restriction . It maybe that you have to remove the ex plate or the head to get at all the passages . Does the thermostat housing look all crudded up......might be a good indication of the rest of the cooling system.
The removal of the head and ex plate involves the removal of corroded bolts and that in itself is a whole nother skill.
I read here somewhere that someone tipped a couple of gallons of vinegar into a tub of water and ran the motor in that ......which aparently got rid of the scale in his motor .........sounds feasible🙂.
This doesnt have to be a hard problem to solve, probly your biggest pita will be removing seized bolts etc .🙂
cody8543
Update took off thermostat housing the thermostat was broken the plastic part is melted into the spring on the thermostat side the top side is also melted
1. How do I check if there is a blockage spray water down the bottom thermostat hole an it ran out the upper exhaust 2 ports spray water into the head hoses an it doesn't come out anywhere but didn't spray alot so don't know how much has to fill before it come out were it's sopose to can post pictures of motor an thermostat if need
cody8543
Took thermostat out an put it back together to see if it will good that way started it up an still not any work the lower foot water pump has been replaced 2 times in the last 2 years all look new no water moving to heads
cody8543
Update drop lower unit the copper lines that run from lower unit to head the rubber grommets weren't there any longer an one one the copper pipes was bent all the hell on the end from the previous 2 shops putting in water pumps incorrectly so now parts ordered an will fix copper pipe an see were it goes
Make sure you have the plastic " guide tubes " in place , to help line up the water tubes.
