scout15246
- Joined
- May 3, 2003
- 4
I have a problem with my idle. The motor has been rebuilt, the carbs have been rebuilt, everything seems to be synced properly. The motor will not idle unless the throttle cable is adjusted almost all the way out. When the motor is cold as well as when hot sometimes will not start unless i spray starter fluid in the carb. In gear, the motor runs great. Also during warm up alot of times i have a ring of fuel in the water around the motor. I am trying to find out if there is any idle speed adjustment that i can make. As well as an air flow adjustment that needs to be made. I have looked at several manuals and still am having a hard time troubleshooting these problems. I NEED HELP, PLEASE !!!!!!!!!!
